Old 27th August 2014, 09:51 AM
THIS RETROFIT HAS BEEN COMPLETED NOW 14/11/2016
Please go to page 2 for the extra wiring you have to do to the Kufatec harness just so you don't have to do this job twice like I did
If you are upgrading from AFS I to AFS II then all you need is wiring on the page 2 of this thread
So far unfortunately I manged only to fit new headlights, wire Bi-Xenons and DRLs.
I'm looking for some motivation to finish it off or some helping hand
I will get there hopefully very soon, so this is the first part of the retrofit.
First you need to get the bumper off to get to this state.
Fit new headlights.
Important!!! Halogen headlight use 10pin connectors and Xenon and Bi-Xenons 14pin connectors.
That's why you need a harness from Kufatec
Connect your headlights using the harness and feed the wires as per pictures below.
You will need to remove the glove box so you will also need tools to get the CD changer out.
Wires will have to go behind the glove box, behind the central console and under the steering wheel to J591 on board power supply.
Route for the wires
J591 location and connection
Two wires with one contact are DRLs.
Single wires are Bi-Xenon left and right
24pin connector on J591.
Locations:
19- Left Bi-Xenon
20- DRLs (left+right)
21- Right Bi-Xenon
CODING via VCDS
[09] Central Electronics I
[Coding]
[Software coding]
ENTER 0143121 for Bi-Xenons with AFS and separate halogen P21W DRL with Automatic Driving Light with rain/light sensor, ENABLED DRLs and set to default
Change your coding accordingly to set up you have.
If you are going to swap your P21W halogen together with 501s sidelight for LEDs as per this thread
http://forum.a8parts.co.uk/showthread.php?t=7192
...then change 3rd digit to [3] IF you have AFS, but follow the above guide (wiring) so the DRL and sidelight are on the same loop
TBC......
ID:	8872   Click image for larger version
ID:	8873   Click image for larger version
ID:	8874   Click image for larger version
ID:	8875   Click image for larger version
ID:	8876   Click image for larger version
ID:	8877   Click image for larger version
ID:	8878   Click image for larger version
ID:	8879   Click image for larger version
ID:	8880   Click image for larger version
ID:	8882   Click image for larger version
ID:	8883   Click image for larger version
