Originally Posted by Architex_mA8tey
1. It's possible to adjust the sunroof from inside the car to make sure that it sits level at the roof line - does it sit level when you look at it from outside>
also
2. You may be affected by what I call the "A8 double glazing issue" - because the car is double glazed on the main windows you can hear all other noises in the car much more than in a lot of other cars (including wind noise on the single pane sunroof presumably)
3. The seal itself may be damaged or worn but I would leave this option until you have eliminated others first!
Good night, the sunroof looking from outside is perfectly adjusted. Also de black seals are Ok, looking from outside.
The point 2 is very interesting and have sense, but is strange, no ?. The Audi dealer it will check the sunroof.
The car only has 6 and a half years, the sunroof is strange that is not good adjusted.
Thank you a lot for your responses guys!!!!
