Old 16th April 2015, 10:03 PM
centurion centurion is offline
i just did another scan today and got the following,
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601180371
Coding: 0004861
Shop #: WSC 02313 785 00200
VCID: 285F1E2B9B06C05EFC3-807D
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 228806 km
Time Indication: 0
Date: 2015.04.16
Time: 09:22:42
couple things - can the clutch [inside the motor mechanism] be replaced? If so, what is the correct part no. and could it be ordered?
In the meantime i will try the trick with violin resin and see how it goes
