i just did another scan today and got the following,
Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 B HW: 4E0 907 289 Component: Komfortgeraet H05 0010 Revision: 00100005 Serial number: W040601180371 Coding: 0004861 Shop #: WSC 02313 785 00200 VCID: 285F1E2B9B06C05EFC3-807D Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0060 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H04 0020 1 Fault Found: 02107 - Trunk or Luggage Compartment Opening Motor (V254) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 3 Mileage: 228806 km Time Indication: 0 Date: 2015.04.16 Time: 09:22:42 couple things - can the clutch [inside the motor mechanism] be replaced? If so, what is the correct part no. and could it be ordered? In the meantime i will try the trick with violin resin and see how it goes ![]() |
