Originally Posted by M-A8
As above
I've recently replaces all upper arms and lower arms and c links between the lower arms and antirollbar, all Lemforder.
I thought about Meile for some time, but in this case nothing is better than oem in my personal opinion so went with that.
For all the arms I've used Mister Auto as they are the cheapest, but lemforder c links you can get only, I think, from experience ecp for £20 each each.
All Lemforder arms from Mister Auto come with oem audi part numbers polished off.
I've recently replaced front track/tie rod ends [only] on mine. Garage had checked all other elements and have not found anything 'wrong' with them but I still get the nasty squeak when the car is cold going over speed bumps in the morning... once it warms up it's all fine but it doesn't feel right on the steering either... it's been to the garage several times and going back in tomorrow morning and if they cannot find anything I was planning to replace all other joints/part on the front suspension. hence i'd appreciate if anyone could list parts and part # associated so that I could order those and close this off once and for all?
Cheerio
