Old 26th April 2015, 11:23 PM
As above
I've recently replaces all upper arms and lower arms and c links between the lower arms and antirollbar, all Lemforder.
I thought about Meile for some time, but in this case nothing is better than oem in my personal opinion so went with that.
For all the arms I've used Mister Auto as they are the cheapest, but lemforder c links you can get only, I think, from experience ecp for £20 each each.
All Lemforder arms from Mister Auto come with oem audi part numbers polished off.
Old 27th April 2015, 01:20 PM
centurion centurion is offline
As above
I've recently replaced front track/tie rod ends [only] on mine. Garage had checked all other elements and have not found anything 'wrong' with them but I still get the nasty squeak when the car is cold going over speed bumps in the morning... once it warms up it's all fine but it doesn't feel right on the steering either... it's been to the garage several times and going back in tomorrow morning and if they cannot find anything I was planning to replace all other joints/part on the front suspension. hence i'd appreciate if anyone could list parts and part # associated so that I could order those and close this off once and for all?
Cheerio
Old 27th April 2015, 01:33 PM
Cheerio
The squeak you hear is from antirollbar bushes mate, problem is that on D3 you can't replace them on their own, there is no even part number for it, all you can do is replace whole antirollbar but it's pointless coz the only thing wrong there is that bloody squeak, and not even always when called.
Also very similar squeak been reported with D3s and it was the actual shock absorber which again needs to replace as one piece.
As you say, there is nothing wrong with the suspension in regards to handling or knocks, it's just bloody squeak.
You live with it or splash few hundreds to replace bar which is fine more likely.
For the arms Mister Auto is great, just type in your reg, go to suspension arms or something like that and just filter parts by manufacturer Lemforder and you done, all there, there won't be two different but same parts, add to basket, pay, wait for the parcel.
Old 27th April 2015, 01:51 PM
Thanks guys.
I think I'm more or less limited to Audi for the bushes.
The droplinks can be lemforder as they are the same as A8's
Old 17th January 2016, 06:17 PM
Just want to report back that Moog rear upper arms are shot after 2 years - especially the offside. Will be getting TRW or Lemforder. Cannot recommend Moogs.
Old 17th January 2016, 06:39 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Lemforder FTW.
[center]
06 3.0TDI Quattro:
Options:
Old 30th January 2016, 03:19 PM
Lemforder FTW.
Thanks Scott. Just replaced both upper arms on the off side using Lemforder. £107 for both from mister auto. Funny how much easier it is the second time, especially after greasing everything that seized. The Lemforder look great and had a black coating non the ball joint pegs. To be fair, the Moog front was fine and the rear probably ok for another year or two. I found the culprit of my knock is the anti roll bar links. They looked fine when the car is on the ground but not after jacking up and taking the wheel off.
