Old 10th June 2015, 01:17 PM
oldnick oldnick is offline
I would concur. Your symptoms sounds like low fluid, and its unusual that a box gets worse immediately after a flush, unless the flush wasn't quite right.
Its quite possible after a bit of a drive the oil has seeped into places it didn't manage to do on the ramp and now the level is a little down.
I once had to take a car back twice to get the level right.... and once filled properly, it was sound.
straight from the horse's mouth !
when the box was factory filled they put in 9.8 litres
after dropping the sump it will sometimes take as little as 8 litres ! how much is drained out doesn't seem to be an exact science !
