Old 20th August 2015, 06:05 PM
Originally Posted by mannyo View Post
Thanks for that, I've tweaked the bottom right and been out for a drive after redoing the basic settings. All angles are still showing zero, and ACC is unavailable so it must still be learning.
Did you switch it off prior to departing for a drive, I forgot to do this once and it said unavailable until I turned it it off and went for the next drive.
Also from reading your symptoms I'm wondering if the -2.7 means the beam is pointing up at the sky, could explain why it only see trucks.
I think a clockwise turn of the lower screw should bring it down
Thanks Matt for the diagram, where dd you get it from?
