Old 29th June 2012, 12:39 PM
Default FS: Heated tinted D2 PF drivers door mirror glass - FLAT
I acquired this last year from another member but then realised it was flat, not convex, and I'm used to a convex door mirror.
So I still don't have a heated outside mirror, but it's not (currently) a problem.
First, it does have a little damage on the mountings (glass is fine) as explained below. Should still fit securely but as I've not actually mounted it I can't 100% guarantee that.
Standard D2 A8 Pre-Facelift FLAT blue-tinted HEATED drivers door mirror.
Part number 4A2 857 536 AA which I believe may fit other smaller Audi models too. Dated 02 96.
The mounting ring on the back has a number of lugs and clips. 2 clips are damaged.
There are 6 very small clips in total in 4 locations:
2 pairs towards the "inner" side, all 4 of these are intact.
2 single ones "outboard. The lower one is missing and the upper one was bent and has been "heat-welded" (by me) back into position so may not be that strong.
If it's any use to you make me an offer to cover P&P and maybe a beer.
Last edited by HPsauce; 29th June 2012 at 01:03 PM. Reason: Title, add FS (For Sale)
