Do I need to remove the front bumper to replace the front driver's side inner PDC (the one that fits in the number plate surround)? Or can it be accessed another way?
Lee 2017 Nissan Leaf Tekna |
you dont have to remove it , just loosen it enough to get your hand in, still requires removal of inner wheel arch, undo the bolts in there enough to pull the bumper forward a little.
How can you test which one has failed? One of my rear ones doesn't work property. Is there any output tests on VCDS as it doesn't show any faults
vagcom tells you which one is faulty
Easy way is to listen to them, if it isn't ticking then it's failed
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Cheers!
Update. Still no fault codes showing on VCDS, so found the measuring block in 001 for rear sensors. The inside rights sensors nearly always shows 0cm, but so times it will work and show 255cm and change as I reverse closer to something.
Will this be a wiring issue, or just a replacement sensor? Taking the bumper off sometime soon to have the exhaust tips painted and a dent removed so would be handy to have a replacement sensor then |
