Old 1st January 2016, 11:15 AM
g-black g-black is offline
How can you test which one has failed? One of my rear ones doesn't work property. Is there any output tests on VCDS as it doesn't show any faults
Old 1st January 2016, 02:32 PM
vagcom tells you which one is faulty
Old 1st January 2016, 10:06 PM
Norretal's Avatar
Norretal Norretal is offline
Easy way is to listen to them, if it isn't ticking then it's failed
Audi TT - 2015 - Ultra
Old 2nd January 2016, 08:45 PM
Cheers!
Old 5th January 2016, 09:09 AM
Update. Still no fault codes showing on VCDS, so found the measuring block in 001 for rear sensors. The inside rights sensors nearly always shows 0cm, but so times it will work and show 255cm and change as I reverse closer to something.
Will this be a wiring issue, or just a replacement sensor? Taking the bumper off sometime soon to have the exhaust tips painted and a dent removed so would be handy to have a replacement sensor then
