Old 13th June 2022, 09:15 PM
Markiii Markiii is offline
Default Damned Parking sensors
Are on the blink again. No errors on VCDS but not a beep to be heard,
any suggestions chaps?
Old 13th June 2022, 09:23 PM
Ronin Ronin is offline
what is the live vcds data showing? can you see the distances? it could be a blown speaker?
Old 14th June 2022, 06:33 AM
A failed speaker will show in VCDS. Check the Fuses. Then as suggested hook up VCDS for the live outputs.
Old 14th June 2022, 02:09 PM
thanks , chaps, it beeps if I press the parking sensor button the dash so doubt its the speaker. I didn't realise i could get real time info on them with VCDS, will give that a try
