Old 3rd September 2012, 10:19 PM
Mutley Mutley is offline
Default Recoding auto transmission to "sport" model
Just came across this, is it valid, anybody else done it ?
http://www.audipages.com/Tech_Articl...nsmission.html
I'm referring to the 2002+ bit at bottom ?
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 3rd September 2012, 10:27 PM
That's for the D2 model (they were a year behind in the US).
Old 4th September 2012, 07:54 AM
That's for the D2 model.
Talking of which, in the US they didn't (I believe) have the PF S8 such as I have, so have higher gears and/or smaller engines.
A lot of that recoding seems to relate to holding lower gears (e.g. first) which in the S8 is kind of superfluous.
Is there any information anywhere about the coding options that would be relevant to my gearbox controller, or is it best just left alone?
For instance I'd actually like it to change it's behaviour (learn) more quickly in response to "spirited" driving yet revert to "very lazy" mode quite quickly.
Reflecting journeys that are often a mix of country roads and dual-carriageway cruising and not over long distances.
