Im driving home from london to newcastle and the glow plug light has started flashing, engine keeps cutting out. Has anyone got any suggestings please?
Also the the car will accelerate if im gentle with the pedal, but if i push to accelerate quickly it cuts out.
Sounds like fuel supply problem, could be simple thing like blocked fuel filter b ut could also be failing fuel pump. Hard to tell without plugging it in.
So i need to get it on vcds
Thanks for your help |
Well i managed to get her home, took 5 hours.
Bought mysef a vcds too, so im going to plug it in today and see if i can find out whats wrong. Do you know if i buy a new fuel pump and fit it myself, will it need to be coded or will it just work. |
Change the fuel filter...that's what mine was
![]() Could be a number of things but that's one of the cheaper options... go for OEM
07 Silver D3 A/S8L Quattro ![]() ![]() |
im going to change the fuel filter now, iv just had it on vcds and got these fault codes
Thursday,18,April,2013,16:40:35:41965 VCDS Version: Release 11.11.5 Address 01: Engine Labels: Redir Fail! Control Module Part Number: 4E0 910 401 J HW: 4E0 907 401 B Component and/or Version: 3.0L V6TDI G000AG 0020 Software Coding: 0011973 Work Shop Code: WSC 02313 785 00200 VCID: 224B3171FD6C1C08178 8 Faults Found: 18279 - Transmission Mount Valve 2 (N263) P1871 - 001 - Short to Plus Freeze Frame: RPM: 0 /min Torque: 167.7 Nm Speed: 0.0 km/h Voltage: 11.93 V Bin. Bits: 1 Bin. Bits: 1 Bin. Bits: 1 Temperature: 61.2°C 19591 - Intake Manifold Runner Control P3135 - 001 - Lower Stop not Reached - Intermittent Freeze Frame: RPM: 756 /min Torque: 93.6 Nm Speed: 0.0 km/h Voltage: 13.60 V Duty Cycle: 88.8 % Duty Cycle: 80.9 % Duty Cycle: 80.9 % Temperature: 87.3°C 17978 - Engine Start Blocked by Immobilizer P1570 - 000 - - Intermittent Freeze Frame: RPM: 0 /min Torque: 167.7 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 11.86 V Bin. Bits: 00101100 Torque: 1035.3 Nm Torque: 89.7 Nm 16619 - Boost Pressure P0235 - 001 - Regulation Range not Reached - MIL ON Freeze Frame: RPM: 2205 /min Torque: 214.5 Nm Speed: 122.1 km/h Absolute Pres.: 1530.0 mbar Absolute Pres.: 765.0 mbar Mass Air / Rev.: 564.0 mg/str Temperature: 22.5°C Duty Cycle: 69.4 % 17471 - Fuel Pressure Regulation P1063 - 001 - Control Range Not Reached - Intermittent Freeze Frame: RPM: 2079 /min Torque: 206.7 Nm Speed: 117.6 km/h Duty Cycle: 1.0 % Voltage: 13.68 V Pressure: 546.7 bar Duty Cycle: 42.6 % Temperature: 36.9°C 17471 - Fuel Pressure Regulation P1063 - 002 - Control Range Not Reached - Intermittent Freeze Frame: RPM: 2079 /min Torque: 206.7 Nm Speed: 117.6 km/h Duty Cycle: 1.0 % Voltage: 13.68 V Pressure: 546.7 bar Duty Cycle: 42.6 % Temperature: 36.9°C 17471 - Fuel Pressure Regulation P1063 - 005 - Control Range Not Reached - Intermittent Freeze Frame: RPM: 2079 /min Torque: 206.7 Nm Speed: 117.6 km/h Duty Cycle: 1.0 % Voltage: 13.68 V Pressure: 546.7 bar Duty Cycle: 42.6 % Temperature: 36.9°C 17471 - Fuel Pressure Regulation P1063 - 004 - Control Range Not Reached - Intermittent Freeze Frame: RPM: 2079 /min Torque: 206.7 Nm Speed: 117.6 km/h Duty Cycle: 1.0 % Voltage: 13.68 V Pressure: 546.7 bar Duty Cycle: 42.6 % Temperature: 36.9°C Readiness: 1 1 0 0 0 i have no idea what this means. lol. |
you'll need to clear all the codes in case they are old ones and try again too just to see what still comes up currently
Fuel pressure regulation could well be related to filter if it's clogged.
Iv cleared them and changed the fuel filter although the one that was one looked to have been changed.
Iv just got two fault codes one for right engine mount short to ground and the one for the transmision mount, but i can live with them for the moment. So all going well i should be ableto make it down to prestige on sunday. |
