Old 28th February 2012, 09:51 AM
in0x in0x is offline
Default exterior handle replacement
audi a8 d3 drivers side door handle is loose , how do i get to look at it, i have taken off drivers door card and there is an aluminium plate after that, which i can't take off any ideas. thanks
Old 28th February 2012, 12:39 PM
sloss's Avatar
sloss sloss is offline
There is a rubber plugged 'hole' in the door frame which lets you use a Torx to unscrew the handle and lift it out.
So when you open the door and look at the latch there should be a cover
Old 21st August 2013, 12:46 PM
gadgetmind gadgetmind is offline
Does that also apply to the handle with the button on it for keyless locking?
Old 25th August 2013, 09:49 PM
47p2's Avatar
47p2 47p2 is offline
You need to remove the door cards and half the bloody insides to get to the handles
Nite Blue 3.0L SE Quattro
