Im presuming they are but i thought id double check anyway!
When i unlock the car sat in the drivers seat i can hear a whirring. I noted as i opened the boot the other day it is coming from that area. More so behind the boot trim. When i turn the car off and remove the key, a loud whirring (like an elecric handbrake winding in the piston) from the passenger ish front of the car behind the dash. Any thoughts? |
Central locking pump?
The locking and unlocking should be almost silent when in the car.
Currently '8-less Previously: - Aqua Blue Pearl D3 S8 - Kamut Beige leather, ACC, B&O, factory RSE, solar sunroof, electric blinds, ski bag, Homelink, comfort headrests. - Aqua Blue D2 S8 - Grey leather/Alcantara - D3 A8 3.0 CVT - D3 3.7 V8 |
That would explain the whirring on unlock, although its not that audible unless you have your head in the boot (thats how i heard it)
Wonder what the one is when you take the key out?? Chris |
The central locking pump is normally audible. Not enough usually to hear it with the engine running, but sat in silence in the driver's seat, if I lock/unlock my door there's a gentle mmmmm sound from the pump in the boot.
As for the noise after turning the engine off and removing the key, I get those too, though again, I would say they're barely audible, not loud. I suspect they're HVAC related. There are a number of motors and solenoids that control ventilation flaps, which I think return to a 'home' position when you switch the ignition off. I believe there's also a coolant pump, to circulate coolant to the HVAC in the 'rest' mode. It's possible that may be running momentarily too.
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 8th May 2015 at 09:01 AM. |
Hmm yes, the flaps will rotate and close once the car is shut down. Good way to demonstrate this is to use the 'rest' function and you will hear the flaps open again. Could be this?
