Fitted my hybrid TV yesterday and have found the signal is appalling, i can't even get the radio stations, when I plugged it in and checked for fault codes it didn't show anything, what I did notice is if you have TV function selected it comes up with a diagnostic screen, and on this diagnostic screen it was telling me that I was only receiving a signal from aerial 3, normally would I be receiving something from all antennas? Or does it switch between antennas shutting off the others?
I read that you can also change the function of the antennas, does anyone know the adaption channel? I've got the DAB unit to install soon but it'll be naff if the signal is just as bad. I've read that the aerial amplifiers can go duff easily, can they be replaced? I'd rather replace than buy a whole second hand unit if I can ![]() Thanks for any advice guys ![]() |
The DAB retrofit guide on here shows the location of the aerial amplifier. They can and do fail, and I was advised that I may find them failed if I were to retrofit DVB-T
http://forum.a8parts.co.uk/showthread.php?t=8151
Thanks for that, I've already been brushing up on what to do so have read the threa already
Not sure about TV aerial amplifier on D3 but on D2 radio/phone aerial amplifier/splitter common problem is dry solder joints. I also had them on mine, so might be worth checking, open it up and resolder joints where wires com in.
Thanks that's not a bad shout, I'll get my iron out and go over what I can see, the module is in the roof by the way just above the rear screen, it's a PCB with Fakra connections all over it, I've yet to open one up so not sure what's inside.
Well got my DAB and DVB working now
![]() ![]() Note to self, make sure the most loop is running the right way round ![]() ![]() Iv also got to get the DAB aerial sorted out as at the moment I'm just using the FM aerial from the radio, I'm getting there though ![]() |
Well I tried to get to the circuitry of the aerial and it's like a bonded rubber over the top making it difficult to peel off without damaging the components underneath and then getting it back on.
I got an AK aerial off some German spares website for £75 iirc so hopefully I have normal TV and reception resolved, if I get bored I can fit telestart on the Webasto too now ![]() |
