Old 17th July 2017, 03:30 PM
Default Aircon saga, wrong fitting
Went back today to ATS Euromaster in the hope to finally get my aircon recharged, but they couldn't do it. Apparently my car has the wrong service vent. They only have one type, with no thread, like a bicycle pump. On my car he service port is threaded. They say must be a European type port, never seen it before. So I can't use the Groupon, have to go to Audi after all.
Have you encountered this problem before? Does your D2 service port look like this?
I can't believe the LHD cars would have a different service port?
Old 17th July 2017, 03:56 PM
That seems odd. Etka only lists one part number of 8A0820855AB with an interchange part number of MT0059. Can you get a photo with the cap off?
Matt
Old 17th July 2017, 06:01 PM
What a load of rubbish - I bet they could do it at full price!
Old 17th July 2017, 06:03 PM
Mine looks like this. He showed me the connection point to the aircon machine, it was too big definitely much bigger diameter than the valve on my 8.
Perhaps most other places carry adapters, I can't imagine all cars have the same valve?
Old 17th July 2017, 06:51 PM
Where is that? Looks well back in the engine bay.
I had my aircon "done" at A8parts after the summer meet and I thought the connector was on the radiator?
(They did inform me that, unlike some systems that have two, there was just a single port.)
Old 17th July 2017, 07:51 PM
+1
When I searched for the part number, the diagram showed the valve being located on the rad.
Matt
Old 17th July 2017, 07:56 PM
Goran, your photo looks like the position and connection for the low pressure switch (8A0959483AA)
ID:	16548   Click image for larger version
Matt
Old 17th July 2017, 07:54 PM
Its just in front of the wiper motor. That's the only location they found, doesn't mean there aren't other, they looked pretty clueless. I did a little research on Elsa beforehand, unless I read it wrong (it is a a bit confusing) that is the service port.
Old 17th July 2017, 07:59 PM
Bottom left in this picture "borrowed" from our sponsors?
Old 18th July 2017, 11:32 PM
27litres's Avatar
27litres 27litres is offline
There are two connectors, but the low pressure one is very difficult to get at hiding between the fresh air intake and the ECU box (along with the heater hoses and auxiliary pumps and anything else they can squeeze where your hand won't fit!).
Standard aircon quick connect fittings won't fit without some sort of extension. My mate did manage to connect it up at some point, but it kept slipping off and he ended up charging it from the high pressure port only anyway!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
