Old 17th July 2017, 06:51 PM
Where is that? Looks well back in the engine bay.
I had my aircon "done" at A8parts after the summer meet and I thought the connector was on the radiator?
(They did inform me that, unlike some systems that have two, there was just a single port.)
Old 17th July 2017, 07:51 PM
+1
When I searched for the part number, the diagram showed the valve being located on the rad.
Matt
Old 17th July 2017, 07:56 PM
Goran, your photo looks like the position and connection for the low pressure switch (8A0959483AA)
ID:	16548   Click image for larger version
Matt
Old 17th July 2017, 07:54 PM
Its just in front of the wiper motor. That's the only location they found, doesn't mean there aren't other, they looked pretty clueless. I did a little research on Elsa beforehand, unless I read it wrong (it is a a bit confusing) that is the service port.
Old 17th July 2017, 07:59 PM
Bottom left in this picture "borrowed" from our sponsors?
Old 17th July 2017, 08:25 PM
A-ha!
Thanks, that explains a lot. So they should have gone for the recharge valve on the radiator. Unfortunately they were not intelligent enough for that.
Elsa does go on to say that the aircon can be recharged through the low pressure valve but unfortunately they did not have an adaptor for that. They didn't seem to have any adaptors at all just the fitting that came with the machine.
Back to ATS I go
Old 17th July 2017, 09:06 PM
The other thing to beware of is that, because it's a single-connection system with a large capacity (800 grams?), it can take quite a while.
I think mine was heading towards an hour to do, not helped by the fact that it actually had too much gas in so took ages to evacuate!
Old 17th July 2017, 09:10 PM
Thanks, that's good to know. I was going to try taking it in the morning before going to work, but if its going to take anything like an hour I'll be very late to work.
Old 17th July 2017, 09:17 PM
Well you might be lucky, but it's definitely not a quick few minutes to do.
Old 18th July 2017, 11:32 PM
27litres's Avatar
27litres 27litres is offline
There are two connectors, but the low pressure one is very difficult to get at hiding between the fresh air intake and the ECU box (along with the heater hoses and auxiliary pumps and anything else they can squeeze where your hand won't fit!).
Standard aircon quick connect fittings won't fit without some sort of extension. My mate did manage to connect it up at some point, but it kept slipping off and he ended up charging it from the high pressure port only anyway!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
