Old 24th April 2020, 08:26 PM
Pellesin Pellesin is offline
Default 16706 - Engine Speed Sensor (G28)
Hello all!
I`ve got a 2004 A8 4,2 petrol (BFM)
Wife called the other day. "It wont start"!
I hooked up the VAG-COM and among the usual complaints as engine mount and system too lean messages I had a new one:
P0322 - 004 - No Signal - Intermittent
The car starts eventually - so far it has not died when driven.
I could not find any info about this sensor or related issues on the forum, so atleast I took a couple of pictures in the process.
So far I haven`t identified the fault. There is no procedure for checking, not even a location in the workshopmanual - dissapointing really!
I checked the resistance of the sensor. it was arount 1K. (Was just under when checking from pin #2 to #3 and just above when reversing - cannot understand why...)
The sensor acts as expected. The resistance value changes, and resumes original value when a metal object is placed on the sensor tip. The same thing happens when the metal object is removed...
Question:
Has anyone experienced the same issue?
Name:	G28 location overview sensor removed.jpg
ID:	23178   Click image for larger version
Name:	G28 location closeup.jpg
ID:	23179   Click image for larger version
Name:	G28 connector with banana jumpers on pin 2 and 3.jpg
ID:	23180   Click image for larger version
Name:	G28 connector closeup.jpg
Old 24th April 2020, 08:35 PM
Very common fault across all models. Just replace it.
Old 25th April 2020, 10:41 AM
IT D3 IT D3 is offline
is this the engine crankshaft sensor?
My thread I created the other day sounds similar - I've bought just the camshaft positioning sensors.. wonder if I should have bought this sensor too
Old 25th April 2020, 01:48 PM
Hello "IT D3"
I saw youre thread, and yes the symptoms sounds alike. Did you get a read out?
Engine refusing to start can be caused bu quite a fiew reasons. One "field trick" I`m not a 100% sure of, but fairly confedent is that if the rev counter comes alive while you are cranking, the G28 is alive since it`s the source of the rpm signal both for ECU and rev counter.
I had lend my VAG-COM to a friend so I could not perform the scan right away.
I had a fuel pump I had plans to replace anyway. (Fault isolation for that system to lean fault). and of course if the fuel pump is dead...= no joy though. The 8 still refused to start some times.
So I "had to do some corona comprimising and get the VAG-COM. That is what lead me on track to the G28 sensor.
I have not yet decided wether or not I`ll replace the sensor, or try further investigation.
I remember having tested a sensor of "similar" type on my old Audi V8 (D11) I`ll see if I can find that test (Involves an LED and a resistor and some stuff). The point is that it flashes if there is a signal. So if it flashes, and the ECU still doesn`t detect a signal - then it`s the ECU that`s faulty. (Yes I have a way of complicating things....)
I`ll give the "stealer" a call monday.
In the mean time I`ll struggle with the head cover gaskets.. words are not enough!
Old 27th April 2020, 10:09 AM
Hi Pellesin, thanks for the reply well I changed the camshaft sensor but had no joy which leads me to suspect the Crankshaft Sensor is faulty.
Does anyone know whether Lucas SEB 1400 Crank sensor is the correct fitment for a Audi A8 2006 3.7 V8 Petrol?
I'm getting mixed matches from eBay some seller say it's a direct replacement others say it isn't.
Very confusing - if anyone can confirm that would be great
Old 27th April 2020, 10:44 AM
Pellesin, don't mean to hijack your thread but it looks like we have the same issue I suspect.
Right, I have been getting all sorts of conflicting information about the Lucas crank sensors.
To be on the safe side I've ordered a Bosch one with part number 0261 210 245 which I hope does the trick.
Is replacement an easy DIY job? My friend and I hope to attempt it this week.
The camshaft sensor's were very straight forward to replace and took about 45 mins tops
