Old 26th March 2012, 11:23 AM
Zip's Avatar
Zip Zip is offline
Question Rear bulb recommendations please
...one of my rears is out. Any recommendations over and above the obligatory Halfords option.
PS: it's one of the in-board boot lid ones. Should the DIS be telling me it's out, cos it's not
Cheers in advance,
Zip
Old 26th March 2012, 11:40 AM
I think you only get a warning on the brake lights.
Can't think of any reason to use other than a bog-standard bulb.
Old 26th March 2012, 12:00 PM
Get them from your local main dealer - surprisingly cheap and generally decent quality. I ended up replacing all of mine as they were all different brightness!
The inner ones have the same fitting (it's offset so make sure it goes in the right way round!) as the outers BUT they need a narrow glass bowl so if they give you a traditional bulb shaped one it won't fit through the hole when you try putting it back in!
Fittings are easy enough - just twist to release
Old 26th March 2012, 01:51 PM
SilverS8 SilverS8 is offline
I've been thinking of trying LED bulbs both for rear light and the brake light.
Just gotta get around to order them
One in my boot is also out, new bulb didnt help. Anyone had that before?
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 26th March 2012, 02:06 PM
I'm not keen on the led look unless you can change every bulb - since there's been some recent discussion on the centre brake light I guess that can be done too. I don't like it if there's a time lag difference between bulbs - it looks odd IMHO
Not sure why 1 wouldn't work unless there's an underlying wiring fault. Do you have 12v available when the light should be on? Sounds like you'll need to trace the fault back if not
Old 26th March 2012, 09:38 PM
Would never buy bulbs from Halfrauds, rear bulb for my old leased car was around 2.99 from them, and 29p from local motor factors, was a decent brand too but dont remember which, try a decent factor, will be much cheaper
Old 2nd April 2012, 06:35 PM
thebluewhale's Avatar
TPS do them for the grand sum of 17 pence each
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
