Old 11th April 2012, 05:00 PM
christhompson's Avatar
Default Anyone do Spanish Garage?
Hi
Our barge has been dripping black oil for a while. Perhaps a teaspoon full on a friend's drive over 24 hours. No noticeable drop in levels but a smear under when we depart. Now in the south of Spain and after a long hard run a slightly larger than usual drip. Into the local stealer. All very friendly, on the hoist, take the bottom engine cover off and then we get an estimate for €1K I can guess at anti-freeze and engine oil items, but any clues as to the rest?
Is our barge dead? I guess it will make it back to our specialist in Abingdon, but will it live on, or should I be calling A8 Parts?
Appreciate your thoughts.
Old 11th April 2012, 05:19 PM
thebluewhale's Avatar
If you can hang on an hour I'll get the missus to translate it for you.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 11th April 2012, 05:31 PM
Standing by in anticipation. Am due to retrieve the car from the stealers tomorrow morning.
Old 11th April 2012, 05:49 PM
47p2's Avatar
47p2 47p2 is offline
Translation is
Please bend down Mr Audi driver, we Spanish mechanics have a big surprise for you
Nite Blue 3.0L SE Quattro
Old 11th April 2012, 07:17 PM
Sorry about the delay Mr T .
OK in my best Spanglish
Juego Ret. 20 - It's a set of something (ret. is abbreviated and we can't work it out. Could be retrovisor-rear view mirror but doesn't make sense in this context)
Cartucho - translates as cartridge. Any ideas?
Tapa Culata - cylinder head (rocker?) cover
Juego junto - Gasket set
junta - gasket/seal
Anticongel - anti freeze
aceite motor - motor oil (96 feckin Euros???)
Aportacion a sigaus - contribution to something (no idea but at 33c the least of your worries)
Varios - various (I worked that one out) Would want a breakdown of that at 120 Euros.
Desaireaction carter desmontado y montado - translates as cranckcase vent (so probably breather) removed and put back (not necessarily replaced)
Junta P. tapa culata - desmontado y montado - rocker cover gasket removed and put back
Tapa culata desmontado y montado- rocker (cylinder head) cover removed and put back
Carter aceite desmontado y montado - crankcase oil (ATF?) removed and put back
Comprobar perdida de aceite y presion - check for loss of oil and pressure
Limpieza y petroelado de motor - clean and not sure but it could be flush the engine.
I hope this helps you out.
It's a bit harder than it looks
Steve
Old 11th April 2012, 07:46 PM
I believe cartucho = (filter) cartridge
Old 11th April 2012, 08:24 PM
If its just leaking oil it looks like a cam cover gasket has gone. Just keep topping up until you get back to the uk. Its a DIY job. Couple of hours and abouit £20.
Old 11th April 2012, 08:58 PM
Sounds almost like they want to do a rebuild
The 'cartridge' could be an oil filter.
If it's only about a teaspoon a day, then I'd just keep on top of it and wait until I got to a garage I could trust.. Not saying these guys have it wrong, but with the language barrier.. you never know.
Old 12th April 2012, 07:59 AM
THANKS guys.
I'm reassured that nothing serious has suddenly happened, and so I think I'll go with the flow and wait until I get back. I'm happy its not a steering rack leak or other nastiness. I don't even have to top it up as the levels appear to be OK. Water doesn't seem to be dropping or getting in either. Must be coming from somewhere, but as its modest maybe the dipstick is not accurate enough to measure the loss. It just looks dramatic on the parking garage floor.
When I visit mates with light coloured driveways, I'll park on the grass.
Thanks again.
Old 12th April 2012, 10:33 AM
sarg sarg is offline
PAS fluid has a quite distinctive smell, as I know from experience, and you should be glad it's not that, replacing the rack is a horrible job
2025 Hyundai Ioniq 5 N
2020 BMW M340d xDrive
