Old 14th December 2012, 09:22 AM
3.7 slp 3.7 slp is offline
Default Inside boot release button not working
Hi all just to see what you think i have found that my drivers door piller boot release botton is not working.....was thinking it could be one of the air lines next to the hinges on the opening....
.....i can hear the air coming out after i have started the car for a time...
Thanks all
Old 14th December 2012, 11:05 AM
What car is it? If it's a vacuum leak, wouldn't that stop the boot opening on the 'blip' button on the key fob too?
Old 14th December 2012, 12:05 PM
47p2's Avatar
47p2 47p2 is offline
Make sure the key position on the boot lock is in the correct position before you look any further
Nite Blue 3.0L SE Quattro
Old 14th December 2012, 04:24 PM
The button in the B pillar and the remote use an electric actuator to release the boot - if it works on the remote (push and hold for several seconds) I'd be pulling the switch and testing the connections to see if there's a continuity fault. If not, it suggests the switch itself is faulty.
Old 15th December 2012, 05:49 AM
sorry its a 2000 A8 qs 3.7.And yes that's what i'm thinking as it works evey time with the key fob
Old 15th December 2012, 05:51 AM
Thanks did check and the boot key position is in the up- down position
Old 15th December 2012, 05:55 AM
Cool thank you will give that a check over..it a new button as the old one feel apart a few months ago...the button dose light up.... but will take it apart and check it.
Is there anything else that i should check out
Old 15th December 2012, 06:53 AM
When I got my A8 the switch to work the boot was broken. Got a replacement from the forum sponsors (A8parts) via ebay, and now it works a treat.
Was the replacement new or secondhand, if the latter then it could have failed.
Old 15th December 2012, 07:48 AM
Good point this one was new from TSP in Leicester was about £15 or so.
Old 1st January 2013, 08:15 PM
green A8 green A8 is offline
Is your glovebox locked? if so this should 'knock out' the pillar switch. This trick has caught me out a time or two. It stops anyone with the service key entering the boot also.
Hope this helps.
Paul.
