Guys,
I am pretty confident I have a faulty MAF (car idles well when it is disconnected). Is it possible to source just the sensor, without the housing etc (looks to be held in by 2 tamper proof screws). Does anyone have a cheap source of this sensor? Car is a 2000 S8 Cheers Scott |
Check the Bosch part number(assuming it's Bosch) on it and search for it online.
The oe number should be 0280218067
The recon bosch number should be 0986280219 Iv got a brand new Bosch unit in the house I bought for mine that i never used that i can sell u if u like. (im a parts advisor for a large motor factors) U can have it at my cost if u need it - it was 57.19 - if u want it u can have it for 60 quid inc postage. |
Thanks Dave,
I will check the part number and get back to you later today, Cheers Scott |
Sure pal, no hurry - it can sit there for another while if not needed for now. Im pretty sure it will come in handy at some point to someone
(I might be interested if not sold elsewhere)
Give it a clean, just for fun, nothing to lose. Take some readings before, put in a ziplock filled with Isopropyl alcohol overnight. Leave to dry. Put back in take more readings and plot the two together to see the difference.
I even brushed it gently with a glass fibre brush. I have one of these, but its too big, so I take a few hairs out and make a small bundle which can fit the opening to reach the metal element. My theory is, if its gunk/oxidation on the metal element surface that's causing low readings, you need to gently scrape it off. Should be possible since thats how electronics contacts/boards are cleaned, IPA and glass fibre brush. http://www.expotools.com/acatalog/10...ush-70530.html or maybe look for a better thinner brush. Ideally a small 90-degree toothbrush with glass fibres is needed. I can chop off some fibres from my brush and send them to you for free if you want to have a go at making yourself a home made mini brush. Perhaps from some 2mm aluminium tubing or similar? |
They are Torx i think and just screw into the plastic, should be able to remove them.
Gents,
Changing my MAF if cleaning does not help. Is the right part for a 2002 3.7 Quattro 434440240? |
Had the MAF out today and cleaned it with carb cleaner.
Now back in the car but not sure what readings I am expecting with VAGCOM? Idle when warm is 680 and the MAF is reading about 4.5 G/S |
Tags |
maf |
