Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 16th January 2014, 06:49 PM
B17NKA B17NKA is offline
Default 57 plate fault code
How do everyone
Does anyone know what engine fault code 06256 means,car is a 57 plate A8 3.0 Tdi
Car runs and ticks over spot on ???
Code does not put any error lights on but keeps coming back on diagnostics
Would like to know what it is for peace of mind
Cheers Andy
Old 16th January 2014, 08:15 PM
mannyo mannyo is offline
from a previous thread,
006256 - Transmission Mount Valve 1 (N262)
You need the rest of the fault code.
and here.
http://www.tyresmoke.net/forum/topic...t-valve-error/
Manny
Past
Old 16th January 2014, 08:26 PM
Thank you mannyo I have read the thread attached still none the wiser like,can I live with it or do I need to get it repaired
I will get the rest of the code,I know it said something about upper limit exceeded
CheerscAndy
Old 17th January 2014, 08:03 AM
It's a rubber mount on the gearbox which can be made stiffer or softer depending on what the engine and gearbox are doing and it has blown so is just a dumb rubber mount now. The symptom would be a small reduction in refinement.
Old 17th January 2014, 05:33 PM
Thanks
I will look at having it replaced whilst car is under warranty
Regards Andy
