Old 24th January 2014, 12:14 PM
Default Boot trim above battery?
Not sure this fits in this section, but can't find any info with the search.
What methods have people successfully used to replace broken clips on that little panel above the battery that forms a compartment?
I've been offered one with 3 clips in place but figure if I can reinstate the 4th it'll put less force on the original 3 and it should live longer!
Adrian
Old 24th January 2014, 12:20 PM
I think I've commented on this before, but I used small screws fitted into the broken-off "stub" at about a 45-degree downward angle.
The ones I used were chrome finish with domed heads, probably small woodscrews.
I just rummaged around in my collection until I found some of an appropriate size where the head needed a tiny bit of pressure to go through the slot.
I think I made a pilot hole with a large needle heated in a gas flame.
Old 25th January 2014, 09:06 PM
I did just the same, but made the pilot with a fine drill bit. Worked a treat
Old 26th January 2014, 07:12 AM
Cheers guys - will have a go at that
Old 26th January 2014, 07:37 AM
I took black colour extra heavy duty Velcro tape and glued strips of it to the boot trim and to the 'door'. I used two component Araldite adhesive.
It worked perfectly. But 3 years later I simply upgraded to full size door.
Old 29th January 2014, 01:16 PM
run132's Avatar
run132 run132 is offline
I bought a brand new full size panel from Hoffman Car Parts in Holland. Looks like they still have some in stock if anyone is interested.
Audi S8 (D2). Audi R8 Spyder V10. Range Rover Sport Autobiography Supercharged. Range Rover Classics (x2). Daimler V8 (X308). Mercedes 500SL (R129). Lexus LS 400. Honda Legend (KA7). Mercedes 320E (W124). Mercedes 300E (W124). Fiat 132 2000 (x8). Fiat 127 Special.
Old 31st January 2014, 10:11 AM
Condor Condor is offline
I ordered one of these a little while ago, very inexpensive compared to local prices and they are quick and efficient. I think they showed as having 3 or 4 left in stock when I ordered mine. If only they had the front bumper grilles too!
