Old 12th September 2009, 08:18 AM
darrenjoe90's Avatar
Default new disks
on recent trip to germany it became apparent that my brakes were not as good as they should be. during the trip and on a few occasions since then the car has had some bad brake fade. so i have now decided to get some new disks. on the front i have gone for ebc vented grooved and dimpled with ebc yellowstuff pads. on the rear i have gone for vented and grooved discs with yellowstuff pads. also a new fluid change with brembo lcf600 brake fluid. hopefully this will cure the problem of brake fade or i will just have to drive a bit slower
ID:	451   Click image for larger version
ID:	452   Click image for larger version
Last edited by Conan_the_Librarian; 14th February 2010 at 11:15 AM. Reason: Embed Photo
Old 12th September 2009, 09:08 AM
gninnam gninnam is offline
Nice - bet not cheap though
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 12th September 2009, 09:14 AM
Botang Botang is offline
After speaking with you the other week I have now experienced some brake fade on my A8 with the same set up. It appears that the problems are to do with cooling more than the pads as such, if you get them very hot they can take a while to cool down so next time you brake they can fade a bit. You might want to consider some better ducting if its a real issue for you as we have seen how effective that is on the track car, and what a difference it made when one of the ducts became partly blocked.
Old 12th September 2009, 09:59 AM
the ebc vented discs are supposed to have better cooling so i am hopeing that these do some good. also both front and rear are grooved to allow gas to escape. its got to be better than my standard discs. i will just see how it goes when they are fitted. as for price andy i paid 170 for the front and 65 for the rear delivered.
Old 12th September 2009, 06:08 PM
Thanks for that - are they ones off of Ebay?
Andy.
Current cars:
BMW i4 M-Sport
Old 12th September 2009, 07:24 PM
the rear ones are off ebay and the fronts i got from a to z motor factors in dewsbury.
Old 12th September 2009, 07:45 PM
A lot of RS 6 owners get a Phaeton cooling duct fitted to their cars, google 'unit 20' they fit them.
Old 13th September 2009, 03:53 PM
CliveH's Avatar
CliveH CliveH is offline
Got them on the S4. Buy them from your local VW dealer and fit them yourself - piece of cake
Old 13th September 2009, 04:44 PM
how much do they cost clive ?
Old 13th September 2009, 06:26 PM
CliveH's Avatar
Default Phaeton ducts
3D0 615 447D - cooling duct left
3D0 615 448D - cooling duct right
3D0 615 311C - splash shield left
3D0 615 312C - splash shield right
You also need some 6mm bolts, although I'm fairly sure they came with the ducts.
About £60 all in I think Darren, but best to check they'll fit the '8 first...
The splash shields needed a bit of cutting to fit the '4
