Old 25th July 2011, 08:20 PM
darrenjoe90's Avatar
Default tyre pressure
I am now running 275/35/20 and have a different pressure in each tire. What PSI should have in each generaly for motoway and fast road driving ?
will also probably change to nitrogen before the german trip
Audi S8 Phantom Black
Old 25th July 2011, 08:48 PM
275/35R20 Y 102
front = 2.3 bar / 34 psi
rear = 2.1 bar / 31 psi
Old 25th July 2011, 09:04 PM
That sounds low.
Took mine to Kwik Fit and had all 4 tyres filled with Nitrogen for only £6.00 the lot
Old 25th July 2011, 09:19 PM
that does sound low. i thought they would be about 40 psi
Old 25th July 2011, 09:35 PM
I've got mine at 44psi but they are 265/35/20.
You need to get it right. Had mine to low and I've lost the outer edge
Darren, did you sort the fingerprint reader?
Old 25th July 2011, 09:40 PM
I run my 19s at about 36-38 psi, so 40+ sounds about right (does it not say inside the fuel flap?)
You having bother with the fingerprint reader? It's fiddly btw, make sure you have two or three fingers registered
Old 26th July 2011, 05:42 PM
That sounds low.
Well it was from http://www.tyre-pressures.com/ and then searching around the D3 A8's until I found the right wheel and tyre size!!
My Kahns are run at 40psi all around but they are 25 and 30 profile
Old 26th March 2012, 09:11 PM
Jake242's Avatar
Jake242 Jake242 is offline
Does anyone know what pressure I should run on my new 265/40R-20 on a D2 PF?
Thanks in advance
/Jake
Old 26th March 2012, 09:25 PM
I'd go wth 40-42 psi
