Old 11th April 2018, 10:24 PM
27litres's Avatar
27litres 27litres is offline
I love your methodical approach MJ - you put a lot of mechanics to shame!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 12th April 2018, 05:22 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Fascinating work as always!
I watch these posts with so much interest
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 12th April 2018, 07:00 AM
Spanker's Avatar
Spanker Spanker is offline
I know how you feel.
I'm actually getting withdrawal symptoms and feeling quite jealous that Vera is now getting all that mechanical love lavished on her D2.
If only MJ would open up an "MJ's D2 Surgery" in the Midlands and make a business of it
Dean
Old 12th April 2018, 07:47 AM
Last night's update this morning since I finished quite late. Time is getting rather tight now with the two new challenges.
Did the CV boot. Caught it just in time - there was hardly any grease left in it, but no dirt and the joint is fine.
New boot
I was not expecting to be removing blue paint this week Cleaned up the area to be welded and chased out the crack with the dremel.
Clamped it down ready for welding
The engine is patiently waiting to go back in
Tackled the leaky power steering hose. Since this is a LHD-specific part there's no way we were getting a replacement in time so I'm repairing it instead. Its leaking from the joint as the crimped joints are loose - a standard D2 failure mode
Carefully cut the old crimps off with the dremel and clean up the joiner and hose ends
Re-crimp the hoses with O-crimps
Cover with adhesive-lined heatshrink for protection and neatness
One of plugs from the old engine. The ash on the tip tells me its burning the oil, but the lack of petrol smell in the sump does reinforce the blow-by through the crankcase vent theory.
Welding commences in about half an hour hopefully...
ID:	18387   Click image for larger version
ID:	18388   Click image for larger version
ID:	18389   Click image for larger version
ID:	18390   Click image for larger version
ID:	18391   Click image for larger version
ID:	18392   Click image for larger version
ID:	18393   Click image for larger version
ID:	18394   Click image for larger version
ID:	18395   Click image for larger version
Old 12th April 2018, 08:07 AM
phew! thought we'd missed the daily update there MJ!
Keep up the good work
Old 12th April 2018, 08:09 AM
That cracked weld is a bit worrying. I wonder if it's a common problem. Can the weld joint be seen/inspected without major disassembly?
Old 12th April 2018, 08:13 AM
I've not seen it before, but its mostly hidden by the header tank and the plastic strut cover. You could see it by removing the cover.
Old 12th April 2018, 08:39 AM
Given that MJ believes the usual cause to be "potholing" then I wouldnt be surprised if its a common problem given the state of the roads. My Indy garage reckons that he sees a big increase in suspension/wheel damage over the past few years as the roads deteriorate.
Old 12th April 2018, 08:54 AM
pete-p's Avatar
pete-p pete-p is offline
Originally Posted by MJ
... I believe this is from hitting a pothole and bottoming out...
If it is a case that the suspension bottomed out, would it not be more likely to happen if the car has been lowered or the suspension stiffened? Or if it was a particularly big hole!
Cars...
Old 12th April 2018, 09:00 AM
That's what I was thinking. The roads around here are in terrible condition too. I had every every single bush, ball-joint and arm on my S8's suspension replaced a couple of years ago (with OEM parts) and already there's knocking and signs of suspension wear again. It's infuriating considering the amount we pay in taxes. I might give those weld seams a check ...
