Extra plumbing for the auxiliary heater:
Plumbing - LPG evaporator down by the AC compressor. Plumbing - tee for the coolant feed to the evaporator (which uses the heat from the engine to evaporate the liquid LPG in to gas) Plumbing - an interesting valve doodad for the aux heater on the right hand side Extra wiring for the LPG system Lots more wiring for the LPG system Wiring disconnected and ready to remove Here's a bonus complication of the manual - the clutch slave cylinder hiding on top of the gearbox. Slightly challenging to remove, extremely challenging to refit! The manual exhaust support bracket is quite tidy with both of them attached together under the gearbox. Engine out: |
