Old 29th October 2012, 09:33 AM
I'm hoping to grab an anti-dazzle mirror as wiring that in properly will involve removing all the same bits of trim as getting the sunroof wiring into place!
Maybe not that difficult.
I know the FL is different around the mirror area to PF, but I just wired my auto-dim mirror into the sunroof circuit quite simply (comments on a thread somewhere) and the only trim I removed was the cover to the sunroof mechanism that you remove to wind it manually.
Can't recall exactly what wiring I found up there, but IIRC there was one +12V wire that was basically live with ignition on (though possibly stayed on for a brief period afterwards to facilitate closing).
Old 29th October 2012, 09:51 AM
True, but I recall Ian saying that to wire it as per factory it needs a reverse feed to cancel dimming, which I quite like the sound of having. Fingers crossed the actual wiring isn't that challenging to find
Old 29th October 2012, 09:57 AM
I think youre right Adrian, its another example of the wiring being in place as standard for most add on options on the PF but not for the FL where bespoke looms were fitted dependant on the spec ordered
Old 29th October 2012, 10:33 AM
In this case the PF didn't have the wiring either, so I had to be inventive.
I didn't bother with the reverse feed and I struggle to think of circumstances where it would have any use.
Old 30th October 2012, 05:09 PM
Night Train's Avatar
I think that they were only 'pre-wired' up to 1997 in PF flavour....
My '98 PF isn't either...
I'm sure Ian will know....
Other vehicles
Oh Yes....... The '98 PF S8!
Old 31st October 2012, 06:35 AM
Definitely not prewired in a 2002 model. I've got an auto dimming mirror ready to go in, but I'm just planning live from the sunroof and earth (sorry Ian!)
Old 6th November 2012, 09:23 PM
Correct.... 1997 onwards your A8 loom will be specific to your cars factory options only....
Old 13th February 2014, 06:27 PM
OK, I sourced my sunroof from Germany and will start my retrofit soon.
In a car with solar sunroof there is a hole in the tray for a sunroof wire.
Can I expect to have the same hole in the tray of a car without solar sunroof?
Old 13th February 2014, 06:36 PM
With the roof panel shut, there are a total of 6 T25 torx screws to remove. 1/4" socket set gave plenty of access. I inverted the panel and undid the screws and lifted the frame off as I was working on my own and didn't fancy dropping it!
Are these screws specific to solar panel only?
Can I reuse the 6 screws that are currently used in my aluminium panel?
The reason why I'm asking is because I sourced only the solar sunroof, but not the complete tray.
Old 13th February 2014, 06:45 PM
thebluewhale's Avatar
I've got as far as fitting the panel on mine. The panel is a like for like fit so you can reuse the screws.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
