Manufacturing info from solar panel
![]() Offside wiring - just cable-tied to sunroof mechanism with some anti vibration foam round it ![]() ![]() Nearside wiring ![]() ![]() Sunroof motor removed off donor assembly - think the wiring plug should sit in the plastic clip that the wiring is sitting in in the picture ![]() Frame part number details ![]() Wiring ready for removal ![]() Contact point removed from end of sunroof rail - there's is nothing to disconnect the wiring at this end ![]() ![]() Having established there's no other way to remove the wiring, this plug needs to come apart. Remove the purple cap with a screwdriver and insert a screwdriver up the end of the plug to press the metal tab on the wire down and pull out the back ![]() Contact points top and bottom ![]() ![]() This is the tab you need to free off to get the wires out of the plug ![]() I didn't take any pics of removing the rails, but basically it's 7x T20 torx on each side and the roof mechanism needs to be more or less right back so the panel mounts are out the way and they can be lifted out. The screws have evidence of threadlock on them and are barely even finger tight - I had a bit of a play around and it's very easy to over-tighten them and the roof mechanism will then feel tight if you operate it by hand (4mm allen key in motor) Given the suggested torque for the screws holding the sunroof panel on is 4.5Nm I'd expect the rails don't need to be any tighter than that. If you have it some threadlock probably won't go amiss, particularly on the rails. I've wrapped the solar panel in bubble wrap for now and won't be fitting it until I have some help available to lift it into place. In the meantime I'm hoping to grab an anti-dazzle mirror as wiring that in properly will involve removing all the same bits of trim as getting the sunroof wiring into place! Adrian
