Old 15th January 2022, 04:06 PM
Ok a mini how-to for CV boots, albeit with the driveshafts off the car which makes it soooo much easier!
The joint itself is good. No water ingress or dirt in there so fine to re-use it
Help, or at least peace of mind required. Have used this thread a number of times whilst undertaking suspension refresh, CV boot replacement. I am on my 4th CV boot replacement and having lost my notes on what I have done before, have had a little wobble over the orientation of the 'races' (hope that's right). Considering I have done this three times before you would think I would remember.
The joint on this drive shaft came off particularly easy - good old whack in the special spot. Took apart, cleaned, laid out and replaced as pic: - noting that the thinner leading edge of the (inner race?) facing up
Now this joint was a particular PIA to get back on, extra assistance with mallet required. Question is, have I got the orientation of the (race's) the right way, it sort of looks like your pic MJ but just having a wobble as I have done the others this way
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
