Old 16th July 2016, 08:42 AM
daandaman daandaman is offline
Default Original factory wiring question
How is the factory towbar wired? I see many westfalia/audi towbar modules on ebay but none of them include the cables or they are with cut off wiring. I'd like to do an oem integration however if I look up the parts catalog number, that wiring kit it comes with an aftermarket westfalia 'box' that is just square with a single row of crappy crimp connector pins. Who could show me how the factory wired the towbar?
Old 16th July 2016, 08:55 AM
I used this kit for mine many moons ago, required VCDS coding and worked with other modules such as suspension and ABS just fine...... Same coding as OEM in-fact.
http://www.pfjones.co.uk/westfalia_f...5227300113.pdf
Old 16th July 2016, 09:04 AM
What does your module and wiring loom look like?
Old 16th July 2016, 10:21 AM
I sold the car over a year ago, but from memory just like this...
vs the OEM one which looks like this
This is the VCDS output for the Westfalia option, note the part number reported
Address 69: Trailer (J345) Labels: 4E0-907-383.clb
Part No SW: 4E0 907 383 H HW: 4E0 907 383 G
Component: Anhaenger H08 0080
Revision: 2A002002 Serial number: 00000116719606
Coding: 0100000000000000
Shop #: WSC 00000 000 00000
VCID: 2F66FA047EF3BB59C75-807A
Basically the Westfalia bar and wiring kit are the same as the OEM, and were supplied by Westfalia to Audi for them to add the logo and their margin
Old 16th July 2016, 10:34 AM
So when you installed it, the trailer connector just plugged in, and the wiring loom also plugs in, and on the car end you need to push some pins into the pre-wired/fused fusebox?
edit: why the F* does everyone just cut off these looms... what do they expect you to do with just the box on ebay 8-|
Old 16th July 2016, 10:46 AM
Two plugs to the trailer control unit, a few connections to the fuse box and also a couple of pins to other control units - all in the PDF instructions I attached earlier.
I suspect it is an economics of breaking a car thing, pulling out looms costs more than they are worth
