D3 - Interior Trims Seats, dashboards, plastics, everything inside the cabin |
can i confirm my thoughts.
drivers seat does not come forward when i push the seat adjustment switch forward. however the seat comes forward if the memory button i pressed.so i know the motor is ok. i presume that it must be the switch. 1) will the switch need replacing? 2) easy job?( prefer no two take the seat out) cheers raj
Audi A8 2011 3.0TDI |
Well, I've had one 8 for a short while where switch wasn't the issue, it was the ECU which is about £80, easy to change but it will throw CP which is £60 on top, but easy to change.
Get a ratchet with a spline bit, can't remember what size, undo all 4 bolts on each seat which is really easy, tilt them back to gain access to ECUs, swap them over (passenger/driver) and see if it goes forward using switch, if it does then it is the ECU , if it doesn't then switch it is. I've never changed a switch on them, but can't see it being a big job.
2006 D3 S8 5.2 V10 Ceramic Brakes, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI , 4 Zone AC, Home Link, All Electric Blinds, Fingerprint, Ski Hatch, Black Extended Leather, Heated Sport Seats, Alacantra, Carbon Trim inc Aluminium Pack 2. 2015 A3 S line 1.4 TFSI - for the missus to keep her away from my car. Standard S-line equipment, no extras. 2006 D3 A8 3.7 V8 - SOLD but not forgotten Last edited by M-A8; 31st October 2016 at 10:53 PM. |
thanks for the info re. ECU
nothing ever plug and play with a D3. another weekend job . thanks again raj
