I upgraded my 2005 A8's parking sensor ECU in February to the C revision that shows the display on the MMI screen. It worked fine since then until today, when I noticed that the display no longer appeared whenever I used Reverse gear or pushed the button on the dash
![]() I've scanned the ECU and there's no DTCs and the coding hasn't changed somehow, so I'm puzzled why it no longer works! Code:
Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720610203793 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 234588EDE204395F59-8076 No fault code found. Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
try doing a reset of the mmi, also i recently noticed when battery low the settings can be lost you you should go to settings and see if parking graphic is selected on mmi.
Thank you
![]() I didn't realise there was a setting for the graphic display, as it had automatically appeared once I updated the ECU. What do you know? It was turned off - which is a bit strange as I certainly never turned it off ![]() Easily sorted ... Thanks - Julian
We learn new things everyday
