D2 - Common Faults Quick links to all known common faults and their solutions |
Service is due so I'm hoping to get it booked into the garage next week ...
I've got a few faults/issues that I'm looking to get fixed while it's in too. Has anyone got any advice or technical info on any of these faults/symptoms that I can pass on to the garage? Firstly, I'm getting a creaking when pressing the brake pedal (whether moving or stationary) that seems to be coming from the o/s/f calliper. Is this common and likely to be a calliper fault? Secondly, I have an intermittent ABS/ESP issue that is recording the following fault code: Quote:
Thirdly, I've had a whirring noise for a while that's engine-speed related (starts about 2000rpm and gets higher pitched with increasing rpm). The garage had a brief look at it when it first occurred but suggested that I "let it develop". They suspected the bearings in the alternator and/or the PS pump. The noise hasn't got any louder in the past few months but I'd like to get it fixed now. Is there any simple way to determine where the noise is coming from? Lastly, I seem to have a bit of front bumper droop. I noticed a while ago that it didn't seem to look quite right. Studying the recent Carding Shed photos (see attached), using Jim's car for comparison, there's clearly a gap that shouldn't be there. Has it been refitted incorrectly or is there some way to adjust it?
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 2nd September 2017 at 01:57 PM. |
Brilliant!
Thanks very much MJ! ![]()
My breaks creak a bit too, I suspect the front calipers, even though they were re-conditioned a couple of years ago. No ill effect so far. Although I will try re-greasing them too as MJ suggests.
The S8 I have in at the moment came in to the workshop with the brakes almost on fire. Turns out the inner pads were jammed solid in the calipers and only the outer pad was moving, caused by rust on the edge of the pad backing plate, plus dirt and brake dust building up on the caliper. The calipers on this one were reconditioned a couple of years ago, but the Brembos are a flawed design in that regard as the clearances are so tight. I pull the pads and clean everything up every oil change which stops them getting stuck
![]() (I also pull and re-grease the front strut pinch bolt every oil change too ![]() |
MJ is always spot on with advice.
![]() I suggest you test the temperature of the discs after a run to see if there is any overheating but its a certainty that wthout some work, it will develop into overheating pads/discs at some point in the near future.
I've just had a quick look under the seat. There seems to be something under the carpet near where the wiring loom enters. I assume that the seat and numerous bits of trim need to be removed to get to it (without resorting to slashing the carpet open)? Quote:
![]() I'll ask the garage to take a look at them and see what they think. Who refurbished your callipers and what's the general consensus for the best place(s) now? I seem to remember there was some mixed experiences/reviews with some of the refurbishers. Is there one particular refurbisher who does a consistently good job? And is there a substantial difference in price between refurbished and new (OEM)?
if the side bumper brackets arent loose / havent moved the it may be that at some point you have caught the bottom lip on a surface which has caused one of the small plastic sliders that the bumper slides on to to break off, partly or completely - this would result in the same issue. New brackets from memory will be between £10 and £20 each so not too expensive if they are damaged
