D2 - Common Faults Quick links to all known common faults and their solutions |
Brilliant!
Thanks very much MJ! ![]()
My breaks creak a bit too, I suspect the front calipers, even though they were re-conditioned a couple of years ago. No ill effect so far. Although I will try re-greasing them too as MJ suggests.
The S8 I have in at the moment came in to the workshop with the brakes almost on fire. Turns out the inner pads were jammed solid in the calipers and only the outer pad was moving, caused by rust on the edge of the pad backing plate, plus dirt and brake dust building up on the caliper. The calipers on this one were reconditioned a couple of years ago, but the Brembos are a flawed design in that regard as the clearances are so tight. I pull the pads and clean everything up every oil change which stops them getting stuck
![]() (I also pull and re-grease the front strut pinch bolt every oil change too ![]() |
MJ is always spot on with advice.
![]() I suggest you test the temperature of the discs after a run to see if there is any overheating but its a certainty that wthout some work, it will develop into overheating pads/discs at some point in the near future.
Thanks, definitely need to look into it then. I often check the disc temperature after a drive after one of the rears jammed on my previous S8. On this one so far no excess heat, just creaking. I guess the ultimate solution is a front brake upgrade lol.
There is a simple upgrade solution for S8's that is bolt on from what I've read and replaces the Bembos with an OEM 4 pot caliper - D3 360mm discs and calipers.
Min wheel size is 18", not that that's a problem for S8's...
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
That was top suspect, but they aren't binding - I checked that.
I've just had a quick look under the seat. There seems to be something under the carpet near where the wiring loom enters. I assume that the seat and numerous bits of trim need to be removed to get to it (without resorting to slashing the carpet open)? Quote:
![]() I'll ask the garage to take a look at them and see what they think. Who refurbished your callipers and what's the general consensus for the best place(s) now? I seem to remember there was some mixed experiences/reviews with some of the refurbishers. Is there one particular refurbisher who does a consistently good job? And is there a substantial difference in price between refurbished and new (OEM)?
