Old 18th May 2010, 07:06 PM
Nick1
Guest
Posts: n/a
Question Red hot wing
Hi guys can any body help after going for a spin ,i noticed the nearside front wing is so hot it is untouchable ,i lifted the bonnet and the header tank is red hot and the top of the hydralic tub thingy is aswell is this normal
Old 18th May 2010, 09:09 PM
Originally Posted by Nick1 View Post
is this normal
In a word, no !
Question is,is it the header tanker heating the wing, or something else heating them both.....
Either way, looks like your cooling system isnt running right....
Are there no warnings on the dash ??
Old 18th May 2010, 09:46 PM
My wing used to get warm at that side, but just a little warm.. How much of a 'run' did you go for?
An hour of full throttle? Or just a drive about?
Old 19th May 2010, 07:04 AM
Nick1
Guest
Posts: n/a
No signs on dash at all,just went went for about 20 min run not realy thrashing it
Old 19th May 2010, 11:43 AM
Nick1
Guest
Posts: n/a
how do i check the cooling system is there anything i can check or do before it goes in the garage and cost me ££££££ .Ican hear the cats ticking would this be the cause of the hot wing and header tank problem
also i have a realy weird vibration coming through the peddals and steering wheel,ive checked the wheel bearings there ok ,when i turn the wheel slightly to the right it seems to go off could this be the tracking or would it not affect it enough to cause a big enough vibration any thoughts would be most welcome before my teeth fall out
Old 21st May 2010, 08:28 AM
jmw748 jmw748 is offline
My S8 is always warm on the wing. Ben changed the radiator recently and it still runs hot. No lights or problems and the temp guage stays at 90.
