Old 15th November 2010, 09:11 AM
jeremyp's Avatar
jeremyp jeremyp is offline
Default Stereo Upgrade Part 2
So after upgrading my headunit (Thread here) I decided to complete the upgrade.
Soon after the headunit, I added an amp - a Blaupunkt THA555 - this fits in the rear "cubby" perfectly and provides front, rear and sub outputs (using the 3 RCA inputs that the head unit gives out):
Then I added 17cm Coaxial Focal 165 CVX rear speakers. The advantage of these was that I could fit them under the stock grills (with a little bit of modification!) and only the keen eyed will spot that the grill sits slightly higher!:
This weekend I built a box for a JL Audio 8W3V3-4 8" subwoofer and fitted it in the ski hatch (having angle grinded out the panel last weekend!):
After that I decided to add an AV panel into the middle consol. This has RCA inputs for the headunit (Aux 2) and a stereo jack input (Aux 1) and a USB input (which also does the ipod) and finally a USB socket for charging any device:
I'm really pleased with the result - I've aimed for subtlety and the resulting sound is fantastic. (I also changed the electric aerial for a whip one - similar to the S8 style)
Jeremy
2000/X Silver 2.8 D2 Sport
Old 15th November 2010, 09:17 AM
Im not a big fan of aftermarket installs, but credit where credit is due and that looks very good indeed...
I like the tidy integration, the center console looks fab...
I'm thinking you'll quickly get queue of folks wanting to do the same
Old 15th November 2010, 09:20 AM
jeremyp's Avatar
Thank you sir
Jeremy
Old 15th November 2010, 10:15 AM
He will. me for one. Top install Jeremy and subtle to boot.
Old 15th November 2010, 11:33 AM
Great write up, have you changed your wood for carbon fibre? Any more pics..
Old 15th November 2010, 01:06 PM
jeremyp's Avatar
Amar
Here is the thread
Jeremy
Old 15th November 2010, 10:10 PM
Originally Posted by jeremyp View Post
Amar
Here is the thread
Thanks, looks great and so much better then that vile wood.
