Old 10th February 2011, 01:53 PM
Default Xenon Plus help
I met the potential buyer of my new car today and he seemed happy with it but one of the Xenon pluses has started to play up yesterday and although it Was fine today I've promised to have this sorted for him before he collects it. Now when I switch them on one headlight flickers and dies. Then sometimes it works. Could it be a bulb or is it more likely a ballast?
Old 10th February 2011, 02:26 PM
You have 3 main components to a xenon light:
Bulb - If this had gone, youd get nothing at all
Ignitor - If this had gone, youd never get it lit either
Ballast - Keeps it going nicely once its lit.
Sounds like the latter? A8parts sometimes have lights in with broken lenses etc, but good ballasts... Its worth giving them a buzz
Old 10th February 2011, 02:35 PM
Thanks Ian, I spoke to A8 Parts but there are four different types of ballasts that it could be. They can't find out from my reg as they came from a donor car. Would you be able to help with identifying the right ballast so I can get it ordered asap
Old 10th February 2011, 07:24 PM
The lights were spot on just now as I drove back from the office. Could some wiring have been pulled loose or moved when doing the belt change?
Old 11th February 2011, 11:16 AM
couldnt be an earthing issue could it Amar?
Old 12th February 2011, 12:04 PM
jayzee jayzee is offline
Most likely as they were 100% before you did the work. Have a fiddle around in there with the lights on to see if you can get it to play up again.
Yeah baby!!
Old 12th February 2011, 07:19 PM
Will do thanks, it flickers like it's about to light up then doesn't now so could it be the ignitor? On the plus side I've been running the car on V Power as too lazy to go to the LPG filling station and it drives like a dream. Wish I'd run it on petrol more often. Could someone tell me where the ignitor is and where to find it?
