Old 12th February 2011, 07:19 PM
Will do thanks, it flickers like it's about to light up then doesn't now so could it be the ignitor? On the plus side I've been running the car on V Power as too lazy to go to the LPG filling station and it drives like a dream. Wish I'd run it on petrol more often. Could someone tell me where the ignitor is and where to find it?
Old 12th February 2011, 08:57 PM
should look like this Amar from memory it is normally inside the housing
Old 18th February 2011, 10:08 PM
Thanks Neil, I popped into Revo yesterday, I couldn't even work out how to get the bulb out. The Xenon plus design on this is different to the ones on my S8. The ballasts aren't mounted to the headlight for starters. Ben had the bulb out in seconds and said it's blown so I will swap them over to see if that's defiantly the case then get another on order otherwise its going to start getting expensive.
As it's dark when I leave work the car hasn't moved for a good few days (apart from my Revo visit yesterday) but I got my dad to drop me to work in it this afternoon and it felt amazing being driven in and as my dad drove off at snails pace (as usual) it made a lovely awesome V8 vruuum noise. I haven't been bothering with LPG lately. V Power all the way and about 24 MPG on the way to Revo
Old 19th February 2011, 04:34 PM
Ben was spot on, turned out to be the bulb in the end. How very odd but at least it's not something more expensive.
Old 22nd February 2011, 04:09 PM
Fitted some new bulbs today, thought I may as well do both while i'm at it and what a great opportunity to change from 4,300 kelvin bulbs to 5,000 kelvin. It's the perfect combo IMO. Still looks OEM but instead of an occasional yellow hue it's now white. I'm awaiting nightfall now so I can try the difference. 5000kelvin should give a little less light then 4300kelvin in theory however the bulbs that were in the car were old and only gave out the same amount of light as a halogen and were no match for my old plus headlights. I'll report back after sunset and some country lanes
Old 22nd February 2011, 05:53 PM
jayzee jayzee is offline
Kelvin on Xenon bulbs changes with age anyway - the kelvin increases, and less less light output as you say.
Yeah baby!!
Old 22nd February 2011, 06:14 PM
Amar
What's the correct fitting for bi-xenon bulbs? Just wanted to check for future reference as the manual very handily says changing bulbs is beyond the wit of intelligent Audi customers and to refer to your dealer
I seem to be in need of a few bulbs - keep getting a bulb failure warning that I'm thinking is brake light, but the lights are working fine statically. I'm thinking one of them may be a cheap dodgy bulb (they're stop and tail so plenty of scope for naff bulbs) so going to replace regardless and see if it cures it. The rear roof light isn't working either, although the map lights are so appears to have power.
Old 25th February 2011, 01:54 AM
martincieslak1
Guest
Posts: n/a
Had a similar issue with my mercedes S430, one of the bulbs was ''on'' but it would flicker, was very weak and the cluster was saying ''bulb burnt''. I switched the left/right bulb to see if it was the ballast or the bulb, and it was the D2S Xenon bulb. Replaced the bulb with a new phillips original bulb and has beeen fine ever since. !
