Old 22nd February 2011, 06:14 PM
Amar
What's the correct fitting for bi-xenon bulbs? Just wanted to check for future reference as the manual very handily says changing bulbs is beyond the wit of intelligent Audi customers and to refer to your dealer
I seem to be in need of a few bulbs - keep getting a bulb failure warning that I'm thinking is brake light, but the lights are working fine statically. I'm thinking one of them may be a cheap dodgy bulb (they're stop and tail so plenty of scope for naff bulbs) so going to replace regardless and see if it cures it. The rear roof light isn't working either, although the map lights are so appears to have power.
Old 22nd February 2011, 06:45 PM
Adrian you will need D2S bulbs. I think my Bi Xenons are from an early car and it actually had D2R bulbs in it, exactly the same as far as I could see though so maybe the R has now changed to S. I'd recommend 5,000k though. No yellow hue like you get on the 4300k. They have made an amazing difference in reflections etc...
Edit: Audi are right in the sense that Xenon bulbs have 20,000 volts going to them when you initially turn them on so keep the key out the ignition and lights of when you change then and you'll be fine. Audi want £100+ each a bulb so don't bother with them, I think standard fitment was osram. Powerbulbs.co.uk should sort you out for about £40ish quid.
Old 22nd February 2011, 07:14 PM
I think S = Straight and R = Reflected. So the R's bounce their illumination onto the back reflector in the headlamp and thence out the front. While I guess straight just bung it straight out the front, with a lens to focus it.
I don't think they are interchangeable.
I investigated importing these when I paid £105 to replace one in an Omega back in 2001/2
Thankfully prices have since dropped
Old 22nd February 2011, 07:30 PM
It might be useful if we could all try and chip in to a database of bulbs and their codes for A8/S8 by model/type and then refer to a table of bulbs on the same sticky?
I for one would find that very useful as reference every time a bulb goes!
Old 22nd February 2011, 07:53 PM
Adrian you will need D2S bulbs.....Edit: Audi are right in the sense that Xenon bulbs have 20,000 volts going to them when you initially turn them on so keep the key out the ignition and lights of when you change then and you'll be fine. Audi want £100+ each a bulb so don't bother with them, I think standard fitment was osram. Powerbulbs.co.uk should sort you out for about £40ish quid.
Cheers chap
I can understand the xenons being a bit of a risky venture if you have to account for clowns wielding screwdrivers digging around to change the bulbs, but the handbook doesn't even tell you how to access the bulbs in the rear of the car (which is obvious when you look and not remotely difficult) or the interior lights (also easy if you've owned a few VAG cars)
I like the idea of the bulb info sticky - would take the risk out for many people.
Another good site for bulbs is www.autobulbsdirect.co.uk - I ordered Philips X-Treme Vision +100% bulbs for my A6 (H7 fit) and just bought another set for my dad's A4 as they are mind-blowingly better than the ones that were fitted. The A6 was dangerous to drive at night in wet weather as you couldn't see unless you put the front fogs on!
I actually find the S8 bi-xenons no brighter than the Philips bulbs above, but they do have nice controlled light pattern.
The auto bulbs site suggests:
Xenon headlights/bi-xenons - D2S
Flash/main beam support on bi-xenons - H7
Main beam - H9 (presumably for non bi-xenon cars)
Interior - 269
Sidelight - 501 (odd fitment)
Indicator (front) - 581
Fogs (front) - H7
Stop/tail - 380
Reverse - 382
Indicator (rear) - 382
Reg plate - 269
Fog (rear) - 382 (not sure if 1 or 2 as not checked)
I suspect there's more than 1 type of interior bulb to cover the map, interior and puddle lights so these could be updated with specific info?
Apparently Philips and Osram are the only 2 manufacturers who make their bulbs in the EC now - the rest are made in China and from past work related experience the QC goes right out the window when they are!
Last edited by Adrian E; 27th September 2011 at 12:11 PM. Reason: amended to incl flash and update fogs
Old 23rd February 2011, 01:02 AM
jayzee jayzee is offline
Ah, the Omega - first production car to use xenon lights circa 1994?
501 -still remarkably common as a sidelight bulb.
Adrian, my rear courtesy light plays up. Bad connection somewhere as I have to give it a tap when the rear doors are open to get it to work on damp/cold days.
Yeah baby!!
Old 23rd February 2011, 08:16 AM
Yeah, my A6 requires the occasional jog to keep it working - this does appear to be utterly dead. Didn't have a suitable screwdriver to hand to remove the cover last night without risk of damage so left it for another day
Old 23rd February 2011, 12:31 PM
Mr K Mr K is offline
Im not particularly amazed by how bright my xenon plus's are, so maybe they need new bulbs? hmm.
Im sure I read somewhere that BMW developed xenons, being the first manufacturer to use them on the 7 series. I could be wrong though.
Old 23rd February 2011, 07:23 PM
What normally happens with these bulbs is that as they age, they become dimmer, and the colour temperature changes towards 6000-8000k - assuming they don't go pop first.
If they are blue, then your light output will be lower, but in my experience, it is more likely the headlamp covers getting dirty inside or potted with stones that reduces their efficiency.
Some headlamp covers have a UV film that goes milky over time. Remove this and polishing the lenses will restore a fair amount of light output
Yeah baby!!
Old 27th September 2011, 12:12 PM
have amended the bulb listing on page 2
Also worth noting if you're replacing your tail light bulbs that although the fitting is the same, the bulb required for the ones in the tailgate itself are the same diameter as the fitting, rather than a traditional bowl shape. Don't have the number to hand - just don't buy 4 expecting them to all be the same!
