Old 16th November 2012, 08:31 AM
Question can some one help me with tyres.please
I have FE 20" wheels and they are getting very low now i have been let down by a tire place but i have phoned up a place about 70 miles away and the only size they have is 275-35-20
Will they fit my wheel i know 265-35-20 would fit but what about the extra bit ?
Stanfard tyres were 255-35-20
Any help would be great
Im not sure if my wheels are 8.5J or 9J i think they are 9J
Many thanks
Old 16th November 2012, 09:00 AM
47p2's Avatar
47p2 47p2 is offline
Many thanks
They should fit without any problems but the speedo will read 2% faster than actual speed. They will also give a slightly softer feel to the ride being a taller sidewall. See attachment
Name:	Screen shot 2012-11-16 at 10.01.06.png
Nite Blue 3.0L SE Quattro
Old 16th November 2012, 09:15 AM
You are a star ! Fair play thanks for that i dont mind a softer ride and the speedo will make sure i dont get a speeding ticket
Thanks again il get the 275s then
Old 16th November 2012, 09:28 AM
Should be able to check the wheel width just by taking the centre cap off
Camspec will do next day delivery if you've got somewhere local that will fit -
Saved me £150 for 4 tyres compared to local places
Old 17th November 2012, 11:10 AM
Right on that screen shot where it said rim size ?...... its got 8.5---10.5
under 275-35-20
dose that mean that a 275 tyre will fit wheels from a 8.5 to a 10.5
so dose that mean my 8.5 FE wheels will fit a 275 35 20 ?
im not sure this is confusing me
Old 17th November 2012, 11:46 AM
It's on the limit, some tyre sites I use say it's too wide.
e.g. http://www.tyres-pneus-online.co.uk/...es-advice.html
Old 21st November 2012, 11:26 AM
roberto's Avatar
roberto roberto is offline
9" maximum tyre 265 ?
ok so audi are wrong then fitting 275 on millions of A8's
so much for penis err sorry PNEUS
What tyres are you after by the way ?
top make or budget?
i have a set of 4 255-35-20 XL budgets brand new never been fitted
Old 24th November 2012, 07:36 AM
I now have 275s fitted they are pirelli p zeros and they fit absolutly fine and are a lovely ride too
Old 16th November 2012, 09:47 AM
you can put 275's on the 9 inch D3 FE rims as I have them on mine but not on the 8.5 rims I think Guy. You're changing the diameter to 15mm bigger but the main thing is that you need the 9" rims to consider using 275's so check that
Old 16th November 2012, 10:29 AM
ok il check them now ...
are they under the center cap the size ?
