.....offside headlight washer!!!
![]() Ok, CV boot as well, but I knew that needed doing. But...headlight washer? wtf? News to me. Just needs a pin sticking in the holes I think, maybe a loose hose. Very annoying. Anyway - check'em when you're in next.... Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
Since last year, if you have xenons and headlight washers then they must work otherwise its a fail.
Mine failed for the same. Both sides not working. Came as a surprise to me, especially as it cost an absolute fortune to sort out.
They had it in for hours to troubleshoot the electrics. Turned out to be a badly protected wire which burnt out in the loom somewhere in the offside wheel arch. Hope yours is an easier fix! |
Sorry to hear that. Hope its easy to sort out.
All sorted. Blocked nozzles....
![]() Advisories on both front anti roll bar linkage bushes, but no real play yet. They've both hardened quite a lot - noticed that doing the calipers last year. Are they replaceable without the arms?? Comment on handbrake efficiency...I'll have a good clean up when I do the rear discs and pads. Suspect the mechanism on the near side caliper is getting sticky again. Anyone found a good way of keeping them clean, 'cos I haven't? Zip
What would happen if you were to cover them with duct tape, so they couldnt see them?
Kinda like taking your spare out if its bald, if its not there it can't fail?
Del ![]() |
