Old 30th May 2014, 11:41 PM
kevinas88's Avatar
kevinas88 kevinas88 is offline
Default Audi A8 Tail-lights as DRL
Hi,
I am new at this, cause I own Audi A8 only more then a month. Today, I received diagnostic cable from Ross-Tech. So I went test it with my car. I added battery level already on my MMI screen, also I added Oil level, but at the minute it's in dark grey, I did little research so I find out that needs activated in "Long Coding also", but I found another feature which I would like add for my car, it's how to do Tail-lights as DRL on Germans web site where I found it's step by step guide for Audi A5, so I am wondering, if I could make it same on my Audi A8, cause I own latest facelift on D3 platform which has awesome LED tail-lights so I would like activate same way as DRL, that always be ON, hopefully I will find some one who has more experience then me with changing stuff on Long coding.
Here is a web page where I found info for Audi A5 page no.6:
http://www.motor-talk.de/forum/aktio...hmentId=680908
Old 1st June 2014, 09:52 PM
Isnt this the "SAE rear lights" option in comfort systems coding section?
http://wiki.ross-tech.com/wiki/index..._System#Coding
+0002048 = SAE Rear Lights (PR-A8U)
Old 2nd June 2014, 07:16 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
What does the DRL rear lights look like?
Side lights?
[center]
06 3.0TDI Quattro:
Options:
Old 2nd June 2014, 11:02 AM
kevinas88's Avatar
Side lights?
Tail lights switch on all the time.. Cause I have on my A8 DRL (day running lights) 5 leds in head light. You have to leave light switch on OFF and activate DRL on MMI so it's lights up twice brighter as usual, but on that mode tail-ligts is off.. I would like to code them to DRL option, when I am activated DRL on MMI that tail-lights light up as well..
Old 2nd June 2014, 03:59 PM
Why not just turn your lights on?
Old 2nd June 2014, 09:59 PM
kevinas88's Avatar
Because DRL are twice brighter as on switch on mode and looks much better on day light when DRL are activated. I will try make some pictures tomorrow.
