Old 16th June 2014, 06:41 AM
Exclamation Help Re coding Abs module
Hi
I fit a new Abs module on the D3 4.2 LWB
The problem has been solved but it now has a massive red brake warning ..
Vag com said abs unit incorrectly coded.
So I followed the procedure and log in ect but it wont accept the new coding it says coding rejected can any one give me an idea why it is doing this please ?
Thank you
Old 16th June 2014, 08:19 AM
I think there's a procedure somewhere out there to do an adaptation before it can be coded.
Old 16th June 2014, 08:27 AM
Could you post the sticker which is in the boot by your spare wheel with all the codes. Base on that I will do my very best to get the right code and full procedure for you ASAP considering I'm very busy today. I've done it before successfully on a 4.2TDi D3.
Old 16th June 2014, 04:56 PM
This is the build..
But my main problem is the abs module is off an A8 W12 and I used the W12 info to log in .. also loged in to basic setting 40168
And it still said coding rejected to re code it for the 4.2 ?
Old 16th June 2014, 05:23 PM
Hi David
Just very quickly as it's mental on my end.
Just to clarify
You've installed a ABS module from W12??
What info you have used from W12?? Coding is a combination of brake calipers etc on the car you fitting it (info on the sticker from your current car not donor), therefore you can't use the W12 coding as this has different components installed. As far as I'm aware. Someone correct me if I'm wrong.
Is a W12 module compatible with 4.2 at all?? This one I'm not sure.
And to clarify, yours is 4.2 petrol ??
Old 16th June 2014, 05:47 PM
Hi yes the W12 module is identical to the 4.2 its the coding that is different
The log in I used for the W12 module is 06137
Long wheel base
18" 1LJ
12 cyl
Auto
And the new coding needs to be
0007597 and that is
Long wheel base
17" 1LL
6/8CYL W/O BREMBO
AUTOMATIC
Old 20th June 2014, 08:31 AM
Hi David
Hi Marcin
I know his forum name might suggest his real name is David, but it's Guy! As in the number plate!
But I'm sure he'll not mind what you call him with the all the help you're giving!
