I think there's a procedure somewhere out there to do an adaptation before it can be coded.
Could you post the sticker which is in the boot by your spare wheel with all the codes. Base on that I will do my very best to get the right code and full procedure for you ASAP considering I'm very busy today. I've done it before successfully on a 4.2TDi D3.
Hi David
Just very quickly as it's mental on my end. Just to clarify You've installed a ABS module from W12?? What info you have used from W12?? Coding is a combination of brake calipers etc on the car you fitting it (info on the sticker from your current car not donor), therefore you can't use the W12 coding as this has different components installed. As far as I'm aware. Someone correct me if I'm wrong. Is a W12 module compatible with 4.2 at all?? This one I'm not sure. And to clarify, yours is 4.2 petrol ??
Hi yes the W12 module is identical to the 4.2 its the coding that is different
The log in I used for the W12 module is 06137 Long wheel base 18" 1LJ 12 cyl Auto And the new coding needs to be 0007597 and that is Long wheel base 17" 1LL 6/8CYL W/O BREMBO AUTOMATIC |
any ideas anyone ??
Hello mate
My apologies, I completely forgot. That day I did mentioned that I'm busy as hell, but yesterday I just forgot as I've had all evening to my self so I was in shock. I'm doing it as we speak. 5min
Hi Marcin
I know his forum name might suggest his real name is David, but it's Guy! As in the number plate! ![]() But I'm sure he'll not mind what you call him with the all the help you're giving! ![]()
