hi guys
![]() the front cigarette lighter in my S8 D2 works for the lighter unit, but not when i plug in the USB adapter for the satnav/car charger. tbh, i think it needs a good clean of the contacts and a proper inspection. this would be easier with out of of the car. does anyone know how to remove the whole lighter unit? lastnight i had a look through elsawin and saw the advisory to bend out the negative prongs with a screwdriver, which is what i tried first off thanks ![]() |
I think, based on my own experience, there's something a bit non-standard about these sockets. I've had problems with various plug-in devices.
If you try the lighter from a D2 in another car for example it often doesn't work as it's too short to reach the contacts.
im going to have another poke about with it. got 90 minutes until motogp time and the soon to be wife is busy ironing and watching dont tell the bride
domestic bliss, everyone in the right place ![]() ![]() |
sorted
![]() in the end, i bent one of the two positive pins into the centre so it allows the usb charger to make decent contact. this means the cigarette lighter will no longer fit, but who cares about that? ive found that my tomtom satnav is very borderline on receiving a strong enough signal to navigate me, i have to put it as far down the windscreen as possible to get a signal, and even then some times it loses where i am! next thing so sort out is the GPS receiver on the boot, no signal detected so i assume its the receiver thats dead. ive got vcds and a pukka cable coming next week, so look forward to getting stuck into the electronics. im an IT infrastructure engineer by trade so this is right up my street ![]() |
On my old S8 it failed and when I looked inside it there was significant corrosion and I eventually wired in an aftermarket (powered) one, located at the very bottom of the rear window (outside) just in front of the boot lid so almost invisible as it was inline with the OEM one but smaller. A bit of rewiring/soldering was required on the lead as the aerial connectors used by Audi are rather different to anything you'd buy aftermarket. I think I've posted pictures somewhere here of what I did, but only the external view, not where I ran the cables and patched in - actually inside the boot lid in the end as it was easier to get at. This was before the days of A8parts of course and a new OEM one was a ludicrous price.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 30th August 2014 at 11:07 AM. |
that was easy to get off
![]() just like yours, mine is corroded pretty badly inside. however when i was jiggling it about getting it off i noticed the satnac has moved somewhat closer to norwich than previously indicated. im going to see if a8parts have one in the correct colour. it doesnt look simple to swop innards as the PCB is attached by a melted plastic pole moulded into the casing :// |
HPsauce,
I've seen you reply to a lot of posts in the forum so I was hoping you could help with a simple question. Where is the fuse for the cigarette lighter sockets? I have checked the 2 or 3 fuses in the boot above the battery and they are fine, I have also checked the 3 fuses in front of the passenger side (I have a RHD) and they are fine. Is there a relay I need to be looking for under the passenger footwell? |
Lighter fuses are documented in the drivers manual, IIRC they are in the normal fuse panel by the RHD drivers right foot.
Long time since I needed to look at those specifically, but I did find them easily enough.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 5th June 2017 at 03:43 PM. |
And #7 Brown according to that picture, presumably the rear one.
