Old 17th November 2014, 08:46 PM
Default Aux inputs on TV tuner
Hi Guys,
Tonight I tried to fit my iphone streaming gizmo only to find that the Aux in is not accepting a video signal.
The audio is ok so I need to investigate the problem, but for the life of me I can't find wiring diagrams for a aux input in elsawin or ebahn.
Am i being stupid?
If someone has the diagram and could post I would be very greatful
Wouldn't mind a link to people selling the harness either, cheers
Old 17th November 2014, 09:00 PM
Check them Del, they are absolutely top guys along the Kufatec, well known across the globe for their kits.
And in the mean time I will look for the diagrams and hopefully (but unfortunately by not finding it either) I will proof you are not stupid
http://vnsmedia.shoper.pl/
Change language to English on the right hand side
Old 17th November 2014, 09:16 PM
This could be silly but have you explored all the media player diagrams??
Old 17th November 2014, 09:25 PM
I think that relates to the AMI???
Old 17th November 2014, 09:27 PM
The harness I have fitted at the minute is into this unit (blue plug
Old 18th November 2014, 06:38 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
This any good?
http://www.audiworld.com/forums/a8-s.../#post24353718
Manual Video- In Adapter A6 4F, A8 4E, Q7 4L
Please disconnect the battery before starting installation.
The TV receiver has to be removed of the left hand side of the trunk (Q7 right hand side). Remove the 20-
pole red connector. Remove the red housing and put the single looms of the adapter into the black
connector as follows:
PIN-configuration:
[PIN 09 – Shield Audio left/right] [PIN 15 – Shield Audio left/right 2]
[PIN 10 – Audio signal white, left] [PIN 16 – Audio signal white, left 2]
[PIN 11 – Audio signal red, right] [PIN 17 – Audio signal red, right 2]
[PIN 12 – Video signal gelb] [PIN 18 – Video signal 2]
[PIN 13 - Video/ Shield ] [PIN 19 – Video/ Shield]
Video output (only for Hybrid-Tuner):
PIN 4 – Video Shield
PIN 5 – Video signal
PIN 6 – Audio Shield
PIN 7 – Audio left
PIN 8 – Audio right
[center]
06 3.0TDI Quattro:
Options:
Old 2nd August 2019, 09:33 PM
Simons's Avatar
Simons Simons is offline
Hi Guys,
Am i being stupid?
I have the opposite problem, the video works fine but the sound doesn't....I ear sound, but totally distortional.
I connect the kufatec cable in AV1 and AV2 pin out but the same result... perfect video and sound distortion.
I checked the cable with a multimeter and looks good. Also with another mirror link, and the same problem always.
What could be the problem?? My car has B&O
A8L 4.2tdi Night Blue Pearl//Torrone Beige & Jive with everything except rear entertainment and fridge
Old 8th August 2019, 09:03 PM
Chip2786 Chip2786 is offline
When I first fitted the Apple TV in my car the audio buzzed like a mofo, I bought a cheap ground loop isolator from eBay and now it’s perfect, could be worth a go
Here’s a linky
https://rover.ebay.com/rover/0/0/0?m...2F250489744414
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 11th August 2019, 04:46 PM
Simons's Avatar
Ok thanks! I'll buy them. I found a cheap one with "gold" plated connectors and CE marking. I'll post the final result 😉
Thanks again!🍻
